Added amp/sub getting feed back from sub
juan84
Mounds view MN
2014 Yukon Denali XL ... Here's what's happening every thing is fine till I close the door tia
Denali2k8
Wires getting pinched in door? How do you have the wires ran? Power ground on one side, signal wires on the other?
juan84
juan84
Mounds view MN
Everything ran separately nothing goes through doors I've heard it could be the active noise cancelling anc just trying to figure this out so I can enjoy the extra bass . Every thing wire to center console to the lc2i
sent from galaxy s6
andy desch
You need to unplug the factory subwoofer from under the cup holder, because of Active Noise Cancellation (which uses the subwoofer)
I had the same issue, and this solved it.
juan84
juan84
Mounds view MN
That's where I tapped the lc2i into .where did u tap for feed
sent from galaxy s6
andy desch
sent from galaxy s6
I tapped into the subwoofer lines under the cup holder and then found the remote wire by the trunk release handle on driver side.
DefiniteDenali
It's the noise cancellation system. It's activated when the doors are closed. Took me months to figure out. There are 2 round vent looking pieces slightly larger than a quarter on the drivers side. The noise cancellation one is the back one I believe. Open drivers door and remove the rubber around the door frame so you can slide your hand between the roof and the headliner.there should be some wire under some foam block. It is kinda hard to pull loose. There will be a green plug on the wire. Unplug the green plug and it should fix the problem. Do not try to pop the covers off from underneath. I did and one broke. Lesson learned. Hope this fixes your issue.
juan84
juan84
Mounds view MN
I'll try that thanks
Sent from my SM-G920T using Tapatalk
juan84
juan84
Mounds view MN
Worked as described!! What a life saver lol . I've had the sub and amp I the Denali but hadn't been able to use them
Off Road Pedia
