Just added an Air Raid Jr......
05Single
afraid of the dark
If you ordered as a kit probably dry airaid filter.
HiHoeSilver
Away!
Chicago
The kit comes either way. On Amazon, you have to select one. Jegs doesn't say which one they send. The kit part # doesn't change, but the filter part # does. See if you can find a part number on/for the filter. If you select that kit on Jegs you'll see at the bottom it says "products you need..." and they try to sell you Jegs cleaner and oil... I do also think that oiled is the default, and dry is the option. This was also the case on Amazon. I had to change the option to dry.
850-135 Oiled or 851-135 dry
adventurenali92
Big Bear Lake, ca
Thinking this is the route I wanna go with my 2006. Is it better to get the oiled or dry filter?
bdubs85
