Ticking sound but only on an incline
rockola1971
Indiana (formerly IL)
You sure it aint your wheel hub(s) bearing(s)? Jack each front tire up of the ground and grab tire at 12 and 6 oclock and try rocking tire in and outward at ONLY those 2 points. Should not be much play at all. If there is then you have a bad hub assembly (wheel bearing).
doc 11 acr
wisconsin
So i just got a 02 Denali and have been fixing a few issues. My drive way has a steep incline. When i pull up my drive i hear this ticking noise. It sounds like it is coming from the bottom passenger side like where the ac condenser is. i have not heard it any other time. Any ideas? It has 185000 miles on it.
I would check your universal joints. That is a classic description of one that is dry and that may fail.
C
cheebs
This might sound dumb but should the u joints be moving if the truck ain't moving?
C
cheebs
Nope. Lets clarify. You dont get the ticking sound when the vehicle is in park and idling?
This sound is when the front end is higher than the rear only. it can be parked or driving. It does change speed with the engine. As I have talked with you guys I have noticed when it happens. I first noticed it when I was parked in my driveway.
rockola1971
Sounds alot like an oil starved bearing, lifter, valve but oil pressure seems good to go. I cant imagine a condition that would cause one to be starved when fornt is higher than the rear unless it were very extreme. Does it ALWAYS make the sound when the front end is higher than the rear regardless if at idle or moving? Can you get us some audio of the ticking?
C
cheebs
Come to find out it was the starter. i changed the starter and the sound is now gone.
SmithMO
