yukon rear passenger taillight
MSborn882007
so my brake light will not come on yet when I have my running lights on,both bulbs in that taillight will come on.anybody have this issue?
M
MSborn882007
haven't checked the fuses yet but wouldn't think that would be it since the driver side works fine. which is the brake switch?
---------- Post added at 03:49 PM ---------- Previous post was at 03:47 PM ----------
nevermind,just figured out what your talking bout. ill check the fuses and then replace that and see.
---------- Post added at 04:33 PM ---------- Previous post was at 03:49 PM ----------
All fuses are good except my rear wiper fuse keeps blowing. Replaced the brake light switch and still no brake light
---------- Post added at 06:07 PM ---------- Previous post was at 04:33 PM ----------
checked with multimeter.with the brakes pressed,no voltage.with just the running lights on,10.3-10.7v.when I unplug the taillight then my drivers side goes out with the brake pressed.came back on after I turned the running lights on and off again
SunlitComet
OBS Jedi-Do Good
unknown at this time.
G400
Rear Body Harness
On the right side B pillar, near the door striker
78907163
Taillamp Harness (w/Trailier Harness. Except Cab Chassis)
At the rear of the left side frame rail, behind the bumper
Left side rear frame rail behind the bumper
G403 Left side rear frame rail behind the bumper
Fuel Pump and Sender (Utility)
Inside the left side frame rail, near the rear crossmember
M
MSborn882007
cleaned the ground with 2 wires on drivers side by receiver and that didn't work.and now rear wiper fuse keeps blowing and the courtesy lights wont come on when I open the door.only when I turn them on with the dimmer.im bout ready to drive the damn thing into a lake
Delta_Chevy
Have you changed bulbs recently? A few years back I bought a two pack of brake bulbs for my Volkswagen. I changed one bulb and everything seemed OK. I noticed some interior bulbs stopped working after the bulb swap but couldn't figure it out. One day I was driving behind my car and noticed the brake light always on. Then I remembered I replaced the brake bulb so I checked it out. The bulb I replaced was the wrong type. There were two different bulbs in the package but they were supposed to be the same. Just a thought!
M
MSborn882007
I replaced the bulb when I first saw it was out.i swapped all the bulbs around when I tried a new circuit board but the brake lights still wouldn't work on the passenger side.i checked the g401 and g400 grounds.i said screw it after that cuz its too damn cold right now.i just noticed today that the courtesy lights wouldn't come on and the rear wiper fuse keeps blowing
---------- Post added at 07:51 PM ---------- Previous post was at 07:10 PM ----------
I noticed the had a few splices before on the harness. would it be worth buying a complete new tail lamp harness?
---------- Post added at 08:33 PM ---------- Previous post was at 07:51 PM ----------
http://cgi.ebay.com/ws/eBayISAPI.dl...akeTrack=true&ssPageName=VIP:watchlink:top:en
M
MSborn882007
I don't know the actual term but theres like 4 or 5 of the clamp style splices. ive found em everywhere on the truck. behind the rear bumper,under the dash,on the wires for the headlight switch,etc. I have no clue what they were tryin to do with em
M
MSborn882007
well I've decided to drop my truck off monday at an auto electric shop to diagnose the taillight, courtesy light, rear wiper issue. $55 for diagnosis so I can deal with that
M
MSborn882007
lol yeah I know.got a lot of stress goin on so I rather just let somebody figure it out for me rather than throwing a wrench through the back glass
CKendrick
