Yukon Fog Lights to LED?
Flynnstone
I just picked up a new 2015 Yukon SLE 2 weeks ago, and want to swap out the Headlights for HID's, and the Fog's for LED's.
Everything i've found online shows two different bulb sizes. The headlamps are size H11, but are the Fogs a PSX26W or a 5202? Any help would be appreciated.
I'm assuming one size is for the 2015 model year, and the other is the 2015i...Not sure the difference between a '15 and '15i either...
jl449
Salinas, Ca.
If your SUV was manufactured after October 2014 then its a 2015i - Date is on driver door. But an easier way to know is if you have wireless charging on the center arm rest then you have a 2015i.
cship
yes I ran into this problem doing mine. I have a 2015i. I will say I love the LED's though because it matches up so well with the main lights. Super easy swap just get underneath twist old out, put new ones in, twist back in, done. took 3 min to do both
juniordaboi909
