WTH is up with the hidden USB Port SIM in 2018 Yukon?
Ct Pirate
Senior Member
I bought a 128 gig micro sim and the adapter to go in the hidden port behind the screen and dumped all my files on it and doesn't work! Seems its not recognized?? SO I go out and buy a 64gig Micro Sim thinking it a capacity issue and load all my stuff on it, pop it in and voila it still doesn't work either!
Samsung 64GB 100MB/s (U3) MicroSDXC EVO Select Memory Card with Adapter
http://Samsung 64GB 100MB/s (U3) MicroSDXC EVO Select Memory Card with Adapter
I toss a old school sandisk 32gig micro card in and it works? WTH man? It's driving me nuts!!! Anyone having any luck with this issue?
Ct Pirate
Ct Pirate
Senior Member
Not sure but I'm going to try a couple more sims and see what the deal is. I would love to just have a 128 and load up all my stuff on it.
yates ™
Resident Apple hater
Iowa
May try a flash drive instead. Not sure if the SD card is meant for music or not.
TechSupport
I have a 128gig thumb drive loaded with music videos and movies in one of the USB ports in the center console and it works fine. Maybe it’s the format of the micro usb or maybe it’s because you are using it with an adapter. I can’t see the CUE system using being able to use a larger thumb drive than the Mylinc
Ct Pirate
Ct Pirate
Senior Member
I just stuck a 128 sandisk stick in and it recognized it just fine so looks like I'll grab one of those mini 128's and try that. I'll keep you guys posted.
https://www.amazon.com/gp/product/B01BGTG2A0/ref=ox_sc_act_title_1?smid=ATVPDKIKX0DER&psc=1
Ct Pirate
Ct Pirate
Senior Member
No didn't need to, it recognized it and music played after I loaded it from my windows 10 machine.
JTRATX
Did you just use that for loading music?
Ct Pirate
Ct Pirate
Senior Member
I did movies and music. But the movies have to be from the rear usb port and can't be in motion. for now ;)
Colin S
I uses a 128gb flashdrive too, behind the screen, with no problems. Just loaded the music on the drive and was good to go. I used the San disk shown earlier in this thread.
Kittmaster
I use a 128GB sandisk usb flash drive formatted as FAT32. Works just fine in there and other ports too. If you are using playlists, ensure the drive path is set to relative in the software you use to create the playlist.....if your not sure, dump all playlists on the drive and just put the songs in the root of the drive and see if you can get it to play "songs" that way to see if its a hardware or software issue.
WITCH1975
