Window Sticker Descrepancy
204Angler
Hi all. I am considering purchasing a 2021 Yukon Denali. I asked for the car fax and window sticker. The sticker shows the Auto Stop/Start with no delete option listed and it also shows power running boards. The car clearly does not have the trailer break, auto stop/start button on the dash, nor the power running boards - just the standard fixed ones. I asked the dealer and he wasn't too assuring. Trying to figure out if something shady is going on before seeing it. It's out of state.
It does have the 6.2L V8 option and thinking maybe that has to do with it? Figured I'd ask the pros.
It also has the ultimate package. Does that make it a denali ultimate or does it just contain some of the options of the ultimate?
204Angler
I did check the Vin number on the sheet and just noticed it's also missing the trailer brake controller listed as well.
204Angler
Hi all. I am considering purchasing a 2021 Yukon Denali. I asked for the car fax and window sticker. The sticker shows the Auto Stop/Start with no delete option listed and it also shows power running boards. The car clearly does not have the auto stop/start button on the dash nor the power running boards - just the standard fixed ones. I asked the dealer and he wasn't too assuring. Trying to figure out if something shady is going on before seeing it. It's out of state.
WalleyeMikeIII
Sunny and Snowy Minnesota
Denali Ultimate as a model did not debut until 2023. In 2022 there was a Denali Ultimate package that had virtually every available option. It would have included power running boards.
I’d make sure you actually have the correct window sticker.
This vehicle does not have the ultimate package, it doesn’t even have the max trailering package. I can tell because it is missing the trailer brake controller, and the two speed transfer case. It also does not have air ride adaptive suspension. It also does not have auto start-stop (maybe a good thing). Can tell all that from the pic of the controls on the left dash.
Get the VIN, go to this link, and replace the vin in the URL with the one from this vehicle (paste the below in the URL field of your browser, delete the VIN in the below, and replace with the VIN from any GM vehicle, and you will get a PDF of the original window sticker)
"https://cws.gm.com/vs-cws/vehshop/v2/vehicle/windowsticker?vin=1GKS2CKD3RR266985"
Alternatively, go to any GM dealer w/ the VIN and. Ask for the vehicle history report and the build sheet. This will list all the installed RPO (regular production options) as well as all the known service/warranty history.
Here is a link describing the things in the various packages for 2021:
Good luck
Those window stickers are generic and not vehicle specific unless you are holding the one that came with the truck in your hand.
204Angler
Good luck
Thanks so much this is exactly what I was looking for.
204Angler
If you do what I said and use the GM link, with the VIN, they are specific
Oddly enough the dealer was right. I am just not sure why this car doesn't have the items listed.
204Angler
It's showing a 2021 deanli with the ultimate package. From the pics It's at the least definitely missing the power running boards, trailer break controller and auto stop/start. Not sure why this is...
2021 was a crazy time with Covid still in full swing, many vehicles were completed missing options or were partially equipped with options with notices to come back later and get them completed.
@WalleyeMikeIII I didn't know you could do that with the newer trucks. I was referring to the internet ones that dealers (not necessarily GM) use which I found to always be generic when looking at GMT900s and K2s for sale.
jforb
Sierra Vista AZ
My mid-22 built Tahoe was missing park assist due to lack of parts, and the window sticker notes that it's missing, gave a credit of $50, and says "includes later retrofit".
so the parts scarcity should have shown up on the sticker?
204Angler
You think I could bring it back three years and 3 owners later? Lol I am getting a little more comfortable with the deal. I dont plan to sell it but worried this issue would pop up if I need to.
204Angler
I have seen this cerdit as well shopping around looking at a lot of stickers but its not on this one. I am worried it's a shady deal. This is only thing stopping be from pulling the trigger so really trying to dig into it here
K2 Kaiju
The Depths
Your gonna buy a used first year Yukon made during the covid/supply chain fiasco? Good luck. The trailer brake says dealer installed which is probably an aftermarket one located in a different location (maybe on right side of wheel?) or it could have been removed by previous owner who didn't tow. Same for running boards - this truck has 3-4 years of previous ownership...
Dkay51
In 2021 there was never an Ultimate Denali. They started producing the Ultimate Denali in 2023 but started showing the Ultimate Denali June 2022 onwards.
Dirk13
I do not think I would buy that car. Way too many questions. Have you verified they are giving you the correct vin? It really looks like that Denali does not have the ultimate package. You’re picking out the things you can see from the pictures, what about all the stuff you can’t see?
The auto start stop button is not really removable after the fact. If it was built without auto start stop, it would say so on the window sticker, just like all the other vehicles from this time.
The trailer brake controller does not say dealer installed, that is referring to the line under it for the illumination package. With ultimate package, this should have had the factory integrated controller and that one is definitely not removable.
K2 Kaiju
The Depths
I see now, the partial sticker pics are a little confusing. I guess I need to get more sleep (may try getting to bed by 8 )...
j_jerry79
