What is this wire?!?!
nross33
Hello guys, I have a 2003 Tahoe base model LS. I took the passenger side door panel hall to check out a blown speaker. This wire I'm not sure where it goes and I don't remember unplugging it or seeing it. Any ideas as to what this may be? 9c1923deba9b47ba1ae99e178472d8b3.jpga3ebe1f9e6e53d30d41e81882106be35.jpg8b151ca6937da433e36154ce392df157.jpg
05Zsvntyfun
Not 100% sure but it's either for heated seats or a different connector for Bose system. It's cheaper for manufacturers to use the same harness on all models than it is to create a separate assembly line. Either way, it's for an option that you don't have equipped
N
nross33
That's what I figured, okay thanks
05Zsvntyfun
Most likely by the wire color. GM speaker wires were usually DG/LG and DB/LB Etc.
It probably is for tweeters. He told me he doesn't have any so it's definitely a possibility
MadDogDelpho
Texcellent
Texas
I've taken my door panels apart plenty of times that I know for certain that that is indeed for tweeters. GM probably just made one harness for all the trucks to cut costs.
N
nross33
I actually do have tweeters but they were unplugged this whole time!
N
nross33
Wait...You have a tweeter in that door that's unplugged and a plug that you don't know where it goes and you're asking us what again?
Previous owner took one tweeter out and I just assumed that it never had them but there was one in the other door. It's weird
GinoTahoe
