What is the best sounding exhaust 03 yukon denali 6.0
SLAMMED DENALI 03
I will be in the market for a exhaust system What do you guys think?? Im not looking to spend a ton of money .Any input is greatly appreciated!
Walkercraig01
its def preference. if your not wanting to spend a lot do a muffler swap. my preference is borla xr1 or flowmaster 50 series. borla being my fav by far. its different.
Walkercraig01
not sure what borla sounds like on 6.0 tho I know the 10 series sounds good on it
adventurenali92
Big Bear Lake, ca
The muffler swap is an easy and cheap way to get better sound. That’s what I did. I went with a simple mavnaflow. It sounds really good. A little louder under heavy throttle but still sounds good and no negative drone inside. And then I took the stock chrome tip off the end of my Denali exhaust and welded on an Mbrp 3.5 inch stainless tip and it looks really good.
S
SLAMMED DENALI 03
Do you have a pic ?
adventurenali92
Big Bear Lake, ca
I believe the part number is 12599. It was a good price ordered from amazon I believe. And all it took was chopping out the stock muffler and welding the magnaflow back in its place. I had a shop do it since it I dont posses those skills but labor was cheap on it. So not a big deal. A great way to beef up your sound without getting too pricey.
01FormulaTA
Corsa, not cheap but zero drone and sounds great at WOT, perfect fitment, etc
CamReynolds
If you want a deep sound look at corsa db its over $600 though. the next deepst was a carven r muffler for $90 which is what i got. It sounds similar to straight pipes but is deeper and has more tone
01subCT
waterbury ct
I bought a dynamax exhaust cause they are 3 inch and readily available at any parts store cause made by walker so they are cheaper then alot of the other stuff.but the muffler was alittle to quiet for next I bought the jegs 2 chamber $30 flowmaster clone love the sound.only thing I noticed tho was I had to add a tip.the tail pipe stopped just short of the edge of the quarterpanel and I had a ton of drone from echo under the body of the truck.threw the tip on so it exited farther and made a night and day difference
Onebadsss
Deerfield, NH
I second this! I’ve tried almost all the major brands in the past and the Corsa Sport systems are the only ones I’ve never had drone or in cabin resonance issues with. Sound great at start up, idle and WOT, all SS construction so you don’t have to worry about rusting. And what extra $$ is spent to step up to Corsa you save in labor to have exhaust work done because their kits are an easy DIY install.
bigb805
Black Widow Venom :head3: Had one welded in the first week I bought it and I love it. The idle is so nice and your neighbors will definitely know when you pull out of the driveway.
HoeRyder26
Mass
I have a 40 Series on mine with 2 2.5" tails to double tips and love the sound. I might change it to a Magnaflow Magnapack and do it in a 3" Single. I lowered it and its super tight with the 2 pipes going over the axle. It's Really hard to make these trucks sound terrible IMO.
915_Tahoe
Your GM Parts Specialist
HELL PASO, TX
I USED A GM MUFFLER PKG ON MY 01 1500HD W/ THE 6.0L, SOUNDS REAL GOOD. QUITE BUT WHERE FLOORING IS HAS THAT NICE RUMBLE TO IT. I BELIEVE I USED THE TOURING MUFFLER INSTEAD OF THE PERFORMANCE ONE, WHICH I WISH I DID USE THE PERFORMANCE.
Docpreston
