What Cam Should I pick
SmileB44Death
Seattle
If like to hear input on the two cams for my 6.2 escalade.
1. TSP 225236 114 3b
2. Tsp CHOPacabra
strutaeng
Dallas, Texas
You should provide more information:
1. Tire size?
2. Axle ratio?
3. Transmission? 4L60e, yes?
4. Torque converter stall speed? Factory?
5. Vehicle use: daily driver? Any towing or off-road? Dedicated track use?
The Chopacabra reportedly loses a good amount of torque down low (if all you do is swap that cam keeping everything else the same,) so probably not a good option, unless you also change to aggressive gearing and high stall speed converter.
I would go with option 1 for a daily driver. The specs look pretty good for a daily driver. What heads do you have on your engine? Rectangular ports?
Edit: he's another cam I've been recommended for a heavier truck. Look at the specs: https://cammotion.com/ls-camshafts/...1aWaxXd5_1yFpNyZj9y5AQyyz_X-_Y2bLHX_C7hkk9Py1
I installed the Summit Racing SUM-8718R1 in my 06 Suburban 6.0. It's pretty mild, but I like it. That's more a towing cam though.
SmileB44Death
SmileB44Death
Seattle
1. Tire size?
2. Axle ratio?
Hello thanks, it will have btr ls7 lifters, high pressure oil pump, and long tube headers. Currently on 33s but looking to go back to stock tires. Also looking for the chop really more than the gains because the truck is heavy anyways. Also will not be doing towing just a daily
Foxy
Go with the TSP Chopacabra Camshaft. I recently installed this in my 2005 Chevy Tahoe and it is mean with aggressive chop! Still has lots of low end torque and much more snappy throttle response. You will not be disappointed!
greenlion
NW AL
Chopacabra for the lope. I think the 225 cam will be too much in a truck with stockish stall and gears.
I have a CC 214/228 114lsa cam in my denali. It has some lope at idle (noticeable but not nasty) and lost some power down low. Pulls hard up top. I have stock size tires (32") 3.42 gears and 2200 stall converter.
HTH
GS Audio
