Transmission Temp question on 2016
momofx
I noticed my trans temp is at 185F - 190F in my 2016 ESV (8 Spd) on a warm day. This is with just two people in the vehicle and also, I have 24 inch wheels. Also I changed the fluid to Amsoil. My old 08 never use to go above 165F even with a trailer! Any concern here?
Just wondering, is there a trans cooler upgrade for these?
Rygrego
Mission Viejo, California
I know there is an updated 6 speed trans fluid thermostat that lowers the fluid temp about 45 degrees, not sure with the 8 speed. My 2016 6 speed never gets higher than 165 ( previously was 204+) with the updated fluid thermostat
M
momofx
Well I took a 3 hr trip and drove around in a lot of stop and go traffic while in 90F weather and the highest it got to was 190F...
Marky Dissod
Regardless of what 'brand' of Dexron6 in use, so long as Dexron6 stays under 221F, everything's fine.
Over 248F, it's a safe guess that the Dexron6 in the torque converter is hotter than 257F.
Even Dexron6 works better under 239F than it does over 239F.
M
momofx
Forgot to mention, I'm actually using Amsoil Signature Series ATF... Doing the oil thermostat mod this weekend. I plan to use a car trailer occasionally so its probably a good idea.
Marky Dissod
Forgot to mention, I'm actually using Amsoil Signature Series ATF ...
You mentioned it.
There's nothing particularly special about Amsoil's Dexron6.
Consider adding either
this
or
this
to Dexron6 the next time you change your fluid and filter.
Doing the oil thermostat mod this weekend. I plan to use a car trailer occasionally so it's a good idea.
It's DEFINITELY a good idea. Your transmission will last longer by more than enough to make it worth possibly losing 1-2 MpG.
M
momofx
Omg I completely forget about that product!! Used it many many years ago on old suv...
B-train
From what my friend says, who is a master GM tech for 40 years, the torque converters on the 8 speed are quite robust and not prone to temp issues like the 6 speed. And, the new HVLP fluid helps the situation. Just be good about service every 40 to 50k depending on driving/trailering
M
momofx
I thought I'd do a 2 year update :p So the Amsoil ATF worked good with the Lubegard and helped a lot with that dreaded shudder but it is still *somewhat* (slightly) there. I did the trans thermostat mod and trans temps stay around 165F - 180F. I'm thinking about going to the Mobil1 LV HP for the trans (I was told to get the blue label one).
Marky Dissod
We appreciate it.
Too many schmendricks don't bother updating.
So the Amsoil ATF worked good with the Lubegard and helped a lot with that dreaded shudder,
Find out whichever is the most modern updated spec for 8L90 ATF, and use that.
Stay away from 'new old stock'.
