Top hose hot...bottom hose cold
Gossamer
Edmond, Oklahoma
Just changed thermostat.
Top hose is hot....heater hoses are hot...but bottom hose to radiator is cold.
Does this indicate air pocket or water pump?
Water pump changed 1 year ago and I purged the system of air.
No pressure building in resevoir....heater blowing hot.
No noise or leaks from water pump.
Gets up to 235-240 degrees then goes back to under 210.
Possibly clogged up radiator....flush?
Thanks
Gossamer
Gossamer
Edmond, Oklahoma
See above.....
No pressure is building up in the reservoir at all. Heater is blowing hot.
RED TAHOE LS
Rossville, Georgia USA
Replace radiator, you'll be good to go. AC Delco parts store carry replacement with great warranty for just over $120.00, don't make the mistake like so many have. JMHO. My original one lasted close to 175k, l/side tank cracked.
David g...............:)
pimp2303
