Thinking about buying a 2dr Yukon gt
Kool rider28
little rock ar
I looked at a 1993 Yukon gt with 170k run go but the rear end has broken gears so I can't drive it. The guy is asking $2000 for it. I thought that was alot for a broken suv. What are these trucks going for$?.
I also have a set of differentials from a 92 suburban to swap with.
I'd pay no more than $800 for that considering you can't even test drive it and it's got that many miles on it...
TahoeTaz
Jersey
I spent $2200 for a '97 and it drove fine (needed cats, brakes, and tires, but ran fine) and has about 10k fewer miles. I agree w/ above, under $1000 unless he wants to get it running for you first.
I'm not all that concerned about the miles as long as it's been taken care of and you can drive it and validate that it's been well maintained but the fact you can't even drive it to see what else may need repair really decrease it's value IMO.
raptorforme93
Tampa, Fl
Well put. The most important thing is that it was taken care of and serviced regularly. If you can get him to take $1,000 for it then I would do it... Especially since you already have the parts to fix it.
K
Kool rider28
little rock ar
It runs fine. Just don't know how it drives. I been looking for several month and every one I have has tranny problem. This the first one with just a broken diff. I wish I could find one for 2k or 3k for that matter and drive it home.
The good thing about this Yukon is that it is a GT and that's what I originally want. Maybe I can talk him down to a thousand?
BattelWagun
Chi-Town USA
Yeah I'd talk him down, It may idle fine, but who knows about the transmission and how she'll run under load (ie in gear). Big pressure related oil leaks and stuff like that may not come out until you do 20 min of good city/highway driving on it...
I'm not what exact options came on them other than cosmetic differences but they are a little bit more "rare" than the other Yukons of the era.
K
Kool rider28
little rock ar
Walking away slowly
Went to talk the owner again and verify the a/c. It didn't work and he would not vome off the price. I had money in possession and everything. He couldn't get to go in neutral bc linkage not connect.
Well if anyone in the little rock Ar area selling a 2 door let me know
You did the smart thing to walk away from that deal, man :Handshake: There was more wrong with that than probably the owner actually knew!
lilman
Hartford,Ct
Give it a few weeks. He'll take $800 for it, easy. Unless he finds some other sucker to buy it. Just wait it out.
raptorforme93
Tampa, Fl
Good luck man! You will be much happier if you hold out and buy the truck that you want than if you settle for something that isnt quite right.
Let us know how it goes :waytogo:
K
Kool rider28
little rock ar
93 blazer one thumb down
Checked out the blazer today. Motor seemed strong but 4wd high didn't work. Put it in 4wd low and it work. Also trans won't down shift to 1st gear. Had to manually put it in 1st and then shift into OD. Needless to say I will pass. The funny thing about the trans was that it was just rebuild and the technician said the problem had some to with electronical side. So he didn't fix it. Must be a hard fix or expensive fix because the owner didn't fix. Also the air conditioner panel wasn't connect so no A/C or radio.
you're smart to pass on that one!
Korbin_A
