Rear window wiper with a mind of it's own ??
mountie
My '05 Yukon.....
Everything was just fine driving home manually using the wiper switch........... Then about 2 miles from home, the rear wiper decided to turn on, and it won't stop wiping. I played with the switch ( 3 options to turn switch) ..... When I turned the key off it kept wiping....
Eventually it stopped, with key off,... not sure what will happen when I turn the key back on.....
I hope there is a FUSE for it ????? And where?????
JonnyTahoe
Minneapolis
One fuse block is under the hood and the other is on the drivers side of the dash across from the drivers door. I had a blower motor do the same thing.
mwilson62000
Senior Member
Drivers side instrument panel fuse box. Top left corner fuse is RR WPR - Rear Window Wiper Switch.
mountie
mountie
I haven't touched the button this morning.....
I had always just manually pushed the button. Maybe I accidentally switched the button to "on' ?
( Not knowing that, I got confused where the button was )?
I need to look at the manual to find out what the difference is in the # 1 or #2 choice is....
...and why it didn't turn off right away.
(( sorry...... A lot of 'posting' for a single button ))
Escalade2007
