Rear right passenger window won't roll up
coachld
I have read several threads about windows not rolling up/down but could not find my problem. My right rear window will roll down from drivers controls but won't roll up with drivers control. However, it will roll down and up from right rear passenger controls. Does not sound like regulator/motor. Is there a connection that might be loose.
I am also having a problem with slow front right passenger window rolling up very slow...especially when weather is cold. I am assuming that is the regulator based on other posts?
Thanks in advance.
mmeachem
It's probably the motor/regulator
I replaced my driver side and installed it myself
Easy Peassy
chauncey0337
MLT, WA
Rear window problem sound like it's the driver's control switch is bad but I would double check the connection behind the door panel.
For the front pass window, the problem does seem to be a bad regulator/motor. Just fyi, it's much easier to change out the entire regulator/motor assembly than to mess with the cables when changing out just motor.
mmeachem
What he said
C
coachld
Thanks for quick responses. Just want to make sure I am ordering the right part. Cost is $41.78 from Partstrain.com. This is description:
Replacement Window Regulator - Front, Passenger Side
2003 Chevrolet Tahoe
Brand: Replacement
Condition: New
Operation: Power
Product Fit: OE replacement
Quantity Sold: Sold individually
Motor Included: With motor
Anticipated Ship Out Time: 1-2 business days
Replaces OE Number: 19120847
Replaces Partslink Number: GM1351110
Warranty: 1-year, unlimited-mileage warranty
ATL
thats pretty cheap, i want to say i paid around $100 for my delco motor/regulator
mmeachem
Yeah that's what I paid but I got mine at a local acdelco warehouse
CAResearch
Yeah I have the except same issue, same window too lol
So if its the regulator, I wonder why I can download at the rear door switch But NOT from the driver seat??
I can hear the switch
KAKALAK
that sounds like your drivers switch. I have the same problem with my 01 rear pass window. I stuck a drill battery on the motor and nothing so im going to replace the regulator assembly.
Tahoer2008
