Rear Differential Bolt Thread/Size
St. Louis
I'm looking at getting a PML differential cover and figured I'd ask if anyone knew the bolt size off hand before going and pulling one and measuring. 2012 Yukon Denali.
8mm-1.25x21
8mm-1.25x16
5/16in-18x7/8
5/16in-18x5/8
8mm-1.25x21
8mm-1.25x16
5/16in-18x7/8
5/16in-18x5/8
mine took a m8 1.25, I put a girdle on it which was pretty thick so I bought longer bolts, so not sure on the length you need for the pml
ace hardware carries more then other typical stores, I had to hit a couple aces because one store had like 5 and had to get the rest at another store
gooffeyguy
St. Louis
Thanks. When ordering the PML, you have to choose which bolts they send with it and the one's I listed above are what I can choose from
BadDaddy2003
