Rear bumper lower trim piece?
Fireman591
Michigan
Does anyone know if the lower (unpainted) trim piece on the rear bumper is interchangeable between trim packages. I have a 2021 LT and would like to add the trim piece from a premier or high country to gain the cut outs for dual exhaust. My plan is to remove the stock muffler and replace it with a better sounding aftermarket muffler along with dual exhaust with some custom tips.
JR09country
Nice idea, id be interested as well.
Sent from my ONEPLUS A6013 using Tapatalk
Toasty
Yes, it's a simple swap out. Swear I've seen a post either in this forum or over on gm-trucks
ryabrams
In the exhaust thread under the “performance” board this was listed as the needed part: #84751055
Gary, any chance you can help me out with the thread title and page #? I tried to find the post you were referencing, but couldn't locate within the 21+ Exhaust thread (was there a different one)? Thanks!
d0wnShifT
Charleston
Does anyone know if there are the correct exhaust hangars on the vehicle for a quad exhaust on vehicle with a single exit exhaust? I looked under my z71 on the driver side rear and did not see where the exhaust would mount.
Maindog
Installed 84751055 dual exhaust lower fascia for my RST. Now I need to figure out what exhaust I wanna install.
Maindog
Installing GM Part # 84751055 rear bottom fascia for dual exhaust exit.
After removing tow hitch cover, remove the 2 metal retaining clips (underneath) that lock it in place and move to new fascia.
Remove black chrome/chrome trim piece. It’s held by 4 white clips that need to be depressed to release tabs.
1 on each end and these 2 middle tabs.
Laredotexas
Can you add more pics of how it turn out ?? Looking to the the same
Laredotexas
did it to my LT. only issue was to find the right muffle shop. Some crazy shop told me it could not be done that the high country had a different frame lol
Did you got aftermarket exhaust tips or they are oem? I am about to pull the trigger on ordering the lower valance.
Laredotexas
Just notice you are also from Laredo…. David did your wrap…. Did Mandó did the exhaust ?
Dh1280
