Question about lift and tires.
jough
Arkansas
Owl, thinks for the Bilstein part numbers...ordered them last night. also picked up a nice set of used Nitto Terra Grapplers in P285/70/17.
owl_93
Nice man. Now you have to wait in anticipation for your parts to arrive! Its like Christmas haha. Those are good tires too. Post pics when you get it all installed
Sent from my Galaxy Note 4 via Tapatalk for Android
ladorn45
At some point i might do a llift on my vechile but not sure. Can i get these shocks that you guys suggested now even if i dont do the lift, or these shocks will only works if i do the lift.
Front shocks: Bilstein (24-186643) 5100 Series Shock Absorber https://www.amazon.com/dp/B00BYNJAVW..._m-R-ub1HW0M01
Rear shocks: Bilstein (24-185783) 5100 Series Shock Absorber https://www.amazon.com/dp/B009FU66FO..._baS-ub104YG2C
Coils: Moog 81069 Suspension Coil Spring https://www.amazon.com/dp/B00498ZR7A..._YaS-ub1K4D3TH
Keys: 1" - 3" Torsion Bar Lift Keys Chevy Half Ton 6 Lug 4x4 Trucks https://www.amazon.com/dp/B00BEN1PXI..._QbS-ub103YDWK
Spacers: 1.5" Lift Rear Axle Coil Spring Spacers Tahoe Yukon Suburban https://www.amazon.com/dp/B00BEN3BEY..._LcS-ub0YPNVHA
TheAutumnWind
IIRC those are fine on stock height as well.
ladorn45
sorry new to this was does IIRC mean and so the bottom shocks would work with stock or a 2.5 to 3 lifted tahoe. Once again new to the whole lift thing
W
willem
Today finally I had time to install the keys and shocks. And after the alignment the ride is way better then before. Deleted the running boards as well. Powder coated the LT wheels and used Cooper Tires (285/70 r17) The shocks I used are the Bilstein 24-186643 and 24-187237, keys (cranked about 2/3), 1.5” spacer and moog Z71 springs. Not the best pictures will make some new ones.
owl_93
Looking great man. Literally exactly what I did to mine. Rides awesome now doesn't it?
Jonrobinson84
Very old thread but these look great! Thanks for all the part numbers and photos.
Can you just crank your stock torsion bars or are the replacements necessary?
owl_93
Stock bars, aftermarket keys. New bars wouldn't hurt though
Sent from my Note 5
4WDTRK
sleeps in garage
Socal dreaming of Norcal
The new keys are necessary to get more lift in the front. The aftermarket keys are indexed differently.
Sent from my SM-G930P using Tapatalk
AppocAlexx
Darth Appocalexx
Abilene TX
Clean looking set up I like it. Next on the list should be an HD hood.
Durobans
