Pushbar suggestions
Garth Knight
I'm looking for a pushbar with fender/headlight protectors that won't obstruct the front camera on my '22 Z71 Tahoe. What brand is usually used on the Police models? I like the tactical look of those versus the ranch style with excessive grilling etc. Thanks in advance for your input!
Sparksalot
Bastrop County, Texas
Setina or Go Rhino
Dropfire93x
You can also try Westin as well. Between Setina, Go Rhino, or Westin, I am sure you’ll find something that works good for you.
Solace
NJ
Westin gives a bit more aggressive look and has the ability to add in headlight wraps and PIT bars.
Setina and Pro-Gard offer a bit more traditional look.
I had a Setina bar on my 2013 Tahoe, a Westin on my 2015, and currently nothing on my '22.
AliBaba
Seattle, WA
Just put a Setina PB-400 on my 23AT4 Yukon Xl. Easy install and looks good.
CTown Duramax
That looks great! I wish Setina or Westin would make one for my 21 Tahoe diesel, but they don't fit the diesel's extra coolers/radiators. I need one b/c there's always something in way!
AliBaba
Seattle, WA
Food for thought…. The Setina mounts the main bracket to the tow hook locations and the upper brackets mount off the crush bumper pad. If you can validate the frame is the same on the crush bumper is the same then it should fit.
RTLINGR2
Sanford, Fl.
I work for a local municipality. All our 21 and up tahoes have setina bumbers. As others have stated, get on the various sites and see what the options are. Look at mounting points. With some manufacturers, there is substantial grille modification needed to make the brackets fit. Others have more features like removable sections in the top tube to install light bars in different width configurations. Also check out pics of different ones installed. Some fit the contours good and others look odd. Personal preference. The setinas are probably the easiest to install with the least modification. In the past I have used go rhino and westin. Westin on newer f150s. Lots of different options with westin, they work good, just to me, they look unfinished, kinda cheesy.
Ken Bike
looked into a Ranch Hand grill guard, looks good and claims all forward sensors and camera will work.
Anyone use a Ranch Hand guard?
RTLINGR2
Sanford, Fl.
Texas DPS has a bunch of them.
Couldn’t tell you on the sensors though.
I have ranch hands on some f450 and 550's , they are both older and fleet trucks, so no sensors. Never seen one on a tahoe. They are nice and cover the headlights like you want.
justinakay79
