Power cable from battery for amp
bsmith8543
Where is the best location in the firewall to run the power wire from the battery for an aftermarket amp in an 09 Tahoe?
Chrisalecia
Northern NJ
There's a video on YT about running it through a grommet on the low passenger side. I'm about to do this also so I'd be interested in other opinions. Also, at the battery there is a terminal point to tie into at the battery itself and also one about a foot back on the firewall. that one is fused though. What would be a better tie-in? At the firewall is cleaner.
---------- Post added at 08:11 AM ---------- Previous post was at 06:56 AM ----------
Check this out Brain. Answers both questions:
http://chevroletforum.com/forum/tahoe-suburban-25/2007-tahoe-add-amp-21865/
vt_hokie2008
VA
I ran my power cable down the driver's side. There's a grommet with lots of wiring going through it behind the brake pedal (up high under the dash). I taped my wire to a metal coat hanger (unfolded) and pushed/pulled it through the grommet.
coolchuck
maybe Escalade bound?
DC Suburbs
Thats how I did mine too. I used a special side post terminal to connect amp power wire to battery.
Chrisalecia
Northern NJ
I was crawling under there today looking for a spot. there really isn't anything other than that big wire loom. The grommet is pretty rugged and taped engine side. Were you able to maintain a good seal after pushing the power cable through? Then there's the other small grommet just above that. The cable that goes through there is stiff like a hood release or something.
Still trying to weigh my options.
---------- Post added at 08:37 PM ---------- Previous post was at 08:10 PM ----------
This guy did a nice job. I think I'm sold:
http://www.gmfullsize.com/forum/showthread.php?p=5142750
vt_hokie2008
VA
I only ran 8 gauge wire, so it sealed up reasonably well for me. I haven't had any leaks or anything.
Sent from my PG86100 using Tapatalk 4
bsmith8543
bsmith8543
Thank you for everyone's input. I am new to this forum and I appreciate the help as I just purchased my Tahoe a month ago. I ended up running the power cable through the passenger side fender and through the boot in the door. Super easy to do and it works great. I will add photos when I get a chance. Thanks again.
Drybone81
