Po304
350VortecSSCT
Westport, CT
threw the engine code betwen 70-100mph...i take my foot off the gas and put it back on and it sounds like its choking or the spark is not being fed.
t_hart
Im having the same prob with my Tahoe Limited, but im getting a P0303 Code. What i do know is...the 030* codes the last number is the cylinder number & it is misfiring. I've read it could be spark plugs, spark plgs wires, dist & rotor. Some say improper gap on that cylinder spark plug. I havent found out whats causing mine yet but when i do i will let you know.Oh & im also getting a P1345 code with mine are you?
Sepiroth
I am here
Kouts, In
Both of you need to have an injector bleed down test performed as well as have your fuel pressure and fuel volume checked.
vsaravia
