99yukon84
So I was driving and I noticed that both my head lights are out so I checked the bulbs they are good. If anyone with any ideas why this could happen would be greatly appreciated
Thank you
Thank you
food, did someone say food?
no high beams knocks its down to the multi-switch in the column if getting headlamp power with switch on and testing the yellow wire going into the switch you have power. going out you should have power on the tan wire when low beam and the light green wire when high beam. if not working on those then multi-switch is bad.
i know it sounds weird what part breaks what function but it happens.
