My cruise won't work
Trexter67
I have a 1996 2 door tahoe. My cruise won't work, I have replaced the switch, the fuse is fine, and I opened the control module and it looks BRAND NEW! What else could it be?
T
Trexter67
Well all my brake lights work fine, I replaced the blinker control arm/ wiper control/cruise control switch
SunlitComet
OBS Jedi-Do Good
unknown at this time.
the brake switch control brake light operation torque converter lock disengagement and cruise control disengagement all on separate terminals. one can function while others don't. usually wehn someone loses the lock up funtion and we ask if they have cruise control or the other way around and they don't we recommend replacing the switch. it is a $15 part at most stores but is a bit cumbersome to get to on he brake pedal. you can test it with voltmeter. on the cruise control disconnect the wiring harness. two wires to check one of which needs the key turned to run but starting not required. when brake pedal is pressed down brake lights should be on and the white wire on harness should read system voltage and the purple wire should not. when released to where the lights go out the effect will be the opposite. purple has voltage, white wire does not.
T
Trexter67
When you said the cruise control wiring harness, do you mean on the cruise control module under the hood? And I don't have a volt meter but I do have a test light, will that work? And did I also mention that when I try to engage the cruise control, the light on the dash does NOT come on
SunlitComet
OBS Jedi-Do Good
yes the connector on the module under the hood. a test lest will do fine. and there is no cruise control indicators on the ipc.
T
Trexter67
What is the IPC
---------- Post added at 03:17 PM ---------- Previous post was at 02:26 PM ----------
Ok I tested it with a test light and it does what it's suppose to. What else could it be?
SunlitComet
OBS Jedi-Do Good
instrument panel cluster. you know, gauges and colorful lights.
---------- Post added at 01:36 PM ---------- Previous post was at 01:35 PM ----------
with key on look for voltage on the brown wire.
T
Trexter67
I've been checking around for lists of wires to check when certain switches are turned and everything is working fine.
SunlitComet
OBS Jedi-Do Good
if all is fine with the wiring and signaling and fuse and the cable is not broken the the module must be replaced.
79192752
Cruise Control Schematic (Gasoline): BRAKE, CRUISE Fuses (Gas) (2 Of 2)
79192753
SunlitComet
OBS Jedi-Do Good
Testing and Inspection
170617472
Cruise Control System Check
Symptom Related Diagnostic Procedures
170617178
Cruise Control Inoperative (Gasoline) (Part 1 Of 3)
189366626
Cruise Control Inoperative (Gasoline) (Part 2 Of 3)
189366627
Cruise Control Inoperative (Gasoline) (Part 3 Of 3)
T
Trexter67
Never mind, I do have a wiring problem
---------- Post added at 09:26 PM ---------- Previous post was at 09:00 PM ----------
I'm getting a little confused, could you please tell me what wire is what color. I'm getting confused at step 8, what color is the cruise release, what color is the brake circuit, and what color is the cruise engaged output?
SunlitComet
OBS Jedi-Do Good
for simplicity (if possible) brake should be white should be the white wire. release should be the purple. and the light blue/black wire signals the pcm that the cruise control is active as the pcm uses the info to effect change on transmission shifting.
T
Trexter67
Sweet, thanks, I will test it all again tomorrow and ill post what happens
TejasPitt
