Mud/Splash guards for Suburban/Yukon XL/ESV
October
The only custom rear mudguards I can find for my 2017 Escalade ESV are the GM ones. They do not fit well against the contour of the vehicle. I had the Husky brand on my short wheelbase Yukon that were perfect, but Husky does not make rear ones for the long wheelbase versions. Front mudguards are interchangeable between long and short versions, but rears are different. Does anyone know any other brand that sell custom mudguards for the rear of the Suburban/XL/ESV versions???
NowZoomer
Search for my post about guards, I put Husky on my ESV with power running boards with no issues
O
October
I have the Husky Liners #59221 which I used for the rears of my Yukon. It does NOT fit my Escalade ESV rears. I called the company and found out the Suburban rears, #59211, should fit the ESV. I did an Amazon order, and will know for sure in 2 days!
NowZoomer
Checked my order, I used 221 on the rears don't see the issue myself
Husky Custom Molded Mud Flaps
Part#: HLR-58201
Style: Front
Vehicle: Escalade Cadillac 2016 1
Part#: HLR-59221
Style: Rear
O
October
Part#: HLR-58201
Style: Front
Part#: HLR-59221
Style: Rear
Do you have an Escalade or an Escalade ESV?
The 59221 fits my Yukon (not XL) and probably fits the Escalade but definitely does not fit the ESV. I have it (59221) on hand and tried it on the ESV and it does not match the contour of the body nor do the screw holes match. I'm hoping the 59211 will do. Hopefully this ordeal I'm going through will be helpful to others on this forum.
NowZoomer
I have an ESV, flap recommended by another ESV owner, he nor I have had any issues
I could be wrong, but it looks like it fits fine
O
October
Interesting.... I took off the #59221 (double checked the model # based on my original Amazon order) from my 2015i Yukon Denali and it definitely does not fit my 2017 ESV. I wonder if there's been a slight mod on the 2017 bumper assembly. Husky liner rep said the ESV has the same contour as the Suburban (not the Yukon XL) and would take the #59211. I appreciate your input and thanks for sharing the pic.
NowZoomer
Strange, I can't explain that but hope you figure it out
Mike Wiitanen
Let me know how the suburban rears, #59211, fit. The husky website does not list any model specific for Escalade ESV, while amazon shows the Yukon 59221 as fitting.
O
October
Nope... the Suburban rears don't fit the 2017 ESV either. I'm planning of modifying the 59221 to fit. The problem is the ridge between the body color bumper portion and the black lower trim below it does not match the notch on the mud guard like it did on my 2015i Yukon. Screw holes also don't line up.
marrickard76
