moon roof
03konxl
I slid the decoration slider under the moon roof forward with roof open,to block Sun.Big mistake!!!Now it doesn't close all the way.Glass works fine.Also,the slider moves forward with glass,instead of staying put,like before.And when you open it,the slider goes back but binds up.WHAT DID I DO!!!!!!
ashelm
Overland Park,Ks
I have a 03 KONXL and with the shade closed the roof pulls the shade open all the way back under the headliner to a point where I cant even see the shade. If I open the shade with the roof closed then open the roof part way I can close the shade only to the point of the open roof. I can NOT close the shade any farther. If I open the vent portion of the roof ( rear of the roof tilted up) I can close the shade all the way. There is some kind of catch on the rear of the roof that controls the shade. BOTTOM LINE you must have jumped over the catch. I would try to open the vent and try to get your shade back in place that way. Maybe you won't have to do anything to the headliner that way. JUST A THOUGHT. Good Luck Scott
vsaravia
