just plugged into my ecm scanner 2006 yukon xl denali
VikingTrad3r
So, i have just been introduced to the world of "scanning". 30$ "elm327" bluetooth + free scan software and i was able to see that my engine with 1900 hrs on it and 330000klm (205000miles) is rock solid.
fuel trims perfect, left bank 3%, right bank 0.6%, all systems normal.
boy does that give me confidence that my wife and kids are not going to get stranded on the side of the road.
i was introduced to the concept of "scanning", i put quotes around it because its not really scanning...its more like watching real time sensor data, 2 weeks ago from watching this video:
about20ninj45
My scanner won't connect to my ecm. I have an 06 Yukon denai xl and I tired two different scanners and none of them talk to my ecm.
V
VikingTrad3r
does your cigarette later work? Not the accessory plugs but the cigarette later
about20ninj45
15 amp fuse for cigarette lighter is working. The elm327 I think that's what's its called connects to my phone, but won't connect to the ecu. The scanner works on my 2014 Chevy traverse and my 2009 Ford escape
V
VikingTrad3r
anybody know the pin that is the 12v power on obd2? u could check that with a multimeter to be sure. then there has to be a wite cut or something.
V
VikingTrad3r
u dont have the pin prong poker things on your multimeter?
like to stick in the right pin to check power?
2006yukonxl
about20ninj45
It was the crappy scanner. I ordered 3 scanners, the kooom elm327 ( two of those) and a bafx elm327 and this was the only lot one that worked.
V
VikingTrad3r
glad u got it sorted out. anything interesting show ip on the scan?
Jumpshot12
