HVAC mode door actuator
westman
I recently purchased a used 99 Yukon. Got it home and realized the air through the vents is not changing. I purchased a new actuator (one close by the gas pedal) and it's still not working. The blend door is working just fine, I can move it by hand. However, the actuator only moves a tiny bit. I pulled the wiring diagram off the net and from what I can see it should have 5 wires going to it. Mine only has three. Can some tell me or take a picture of theirs so I may compare?
rayninglead
Michigan
Is it only coming out of vents and no where else? Your actuator has 2 linkages make sure they are both connected.
2door2wheel
New York
i had this exact same problem in my 99 hoe. it turned out to be the dash controls believe it or not
W
westman
I'll probe the white wire tomorrow, I'm thinking 2door2wheel is on to something with the dash controls. The more I explore common troubles, the more I learn the HVAC controls are prone to failure.
W
westman
Well, after months of procrastinating I finally fixed the problem. The head unit was bad. Replaced it with an ACdelco and everything works!
lfh2indiana
