Hp tuner and dod disable
Kevinf89
Hey guys im doing the dod delete i have a gm 12689035 stock replacement cam non dod keeping vvt and i have the texas speed kit if anyone has used hp tuner do i need to just disable dod once im done?
Just Fishing
Can't fix stupid
Utah
Yes you need to flip an option in engine for the "enabled" to false.
and if you're also removing the vlom you need to disable the sensor stuff.
Search Youtube for it it. ;)
You should only need a single license for the ECM, just select "Don't write" for the others, or only pull the ECM when doing the read.
Reaper21
