Heated and Cooled Cup Holders
376ci
376ci
Canada
I don't understand your question, the console has nothing to do with the wiring?
I took my power and light sources from the HVAC connector and made my own harness.
Just to make this clear, nothing from the escalade center console cup holder assembly fits a Denali/Yukon.
M3kanic
I'm talking about transplanting the entire center console of an Escalade.
Sent from my SM-G900V using Tapatalk
petethepug
Michael
SoCal
Has anyone else installed the Escalade Heated and Cooled Cup Holders in their Denali?
59294
This is good info. I've seen a previous write up / or pictures of this modification. It may have been in a Tahoe. I stumbled into a seller on eBay selling the later version of the units for $100. Grabbed one back then and it's sat on the project shelf for quite a while. When I install mine I'll likely have another Denali standard cup holder to hack up and work off of so there isn't a gaping hole in the console.
Here's what I'm working with. The 1st start of this little project is to determine the pin out of the connector and verify it's in good working order. I should find out really quick what the "scrap" tag means.
08grey
I thought the amp from the denali made a fitment issue.
Sent from my SM-G950U using Tapatalk
petethepug
Michael
SoCal
It's been done more than once and worked around. We'll see what's going on once I'm in there. I'm in no hurry so I'm also going to see if I can find part of the harness for it at a scrappy.
petethepug
Michael
SoCal
Anyone know of a good Escalade wrecker in Cali. I’d like to have them pull the harness for this cup holder or at least get the matching harness clip and straggling wires to start a bench test.
subway truck parts in Sacramento, and there is a few others on sunrise blvd in rancho cordova in nor cal, they get all the nor cal wrecks
Ponchonutty
New Washington, Ohio
For those of you that have these heated/cooled cup holders, can you operate both at the same time? I test drove a Platinum today with these cup holders and it appeared I could get one or the other to work but not both at the same time.
petethepug
Michael
SoCal
Yes, you can run each one of the heated or cooled cup holders at the same time, in heated or cooling mode.
Unfortunately I need to leave the heated / cooled cup holder project incomplete. With the COVOID 19 event lowering the value on vehicles to an extreme, it was actually easier to sell our 08 Denali when it's in pristine condition and purchase an 09 Platinum ESV. Here's what's under the Platinum heated and cooled cupholder.
Nothing special except the Delphi 6 Pin female harness connector # pa6 gb20 gf10. Both the male and female are readily available online along with the timer pin connectors to make a female harness end.
Below is where the rectangular hollow air exhaust exits heated or cooled air from the each one of the TED (thermal electric device) on the passenger and drivers side of the console. It's the little plastic square grill in the carpet next to the seat.
briannorris
