heat/AC air routing question, trying to locate source of bad smell
slowride
Im getting a smell of mouse piss through the vents of my 06 Tahoe only when using heat settings, no smell at all when using the AC. I let this vehicle sit for about a year outside at a storage place and I think mice might have built a nest in there somewhere and Im trying to figure out how the HVAC system works so I know where to look. Do the heat and AC have different routing? I was thinking if there was a mouse nest or whatever in the outside air inlet or the blower motor area I would get the smell out the vents either way with heat or AC on but as I said I only get the smell when its turned to heat. Thanks for your help
GMT800 2005 Tahoe Z71
Navy Supporting Member
PG01
Up here to the right
Yeah, mouse piss has that distinctive smell. Go up under the dash on the passenger side and pull down the kick plate... 5-6 screws. Youll see the blower motor and filter cover ( if installed) I’d start there. They prob have the nest right under the kick plate.
PG01
Here’s some pics
S
slowride
Thanks for the pics, will take a look in there. The Tahoe has rear heat and AC as well but the smell only comes out when running front heat. Yeah unfortunately I have enough experience dealing with mice that I have learned their smells
S
slowride
I dont see where the cabin filter is but feel free to educate me. I was trying to see how I could access the area to the left of the blower, towards the driver side, to check in there but I couldnt find anything online other than instructions for removing the dash to change the heater core.
Fjs0001
2005 didn't have a cabin filter. Mine had a bad smell and I sprayed an entire can of lysol into the AC air intake to kill the bacteria.
Hodmjstone
