Ok so talked with Nathan and i am going to post this here for now.
being that this pertains to OBS, NBS, NNBS i decided this location for starters
ok here goes.. thinking of regearing
now what information i am after is any of you that have regeared to lower gears..
with this said i am after information like what ratio you started with adn what you went to and a comparison of MPG, power gain, what was your RPM shift. aka what you cruised at before at a set hwy speed..
no yes i know the transmissions are different.. 4l60 4l80 the 6 speeds etc.. i know those trans ratios effect the MPG lets leave those variable out. if you simply tell me start ratio and end ratio and you you like and economy and power i can do the other side..
Start gear ratio
end gear ratio
opinions
tire size
how you like
rpm before and rpm after at a given speed
effects of fuel economy...
thanks all
Start gear ratio
end gear ratio
opinions
tire size
how you like
thanks all
