g80 - slip additive or not ?
arctic388
going to change gear oil. have a G80. do i need the slip additive?
arctic388
arctic388
thanks man - i keep hearing about the bomb and i cringe every time i feel mine lock up but what is an alternative to replace it? i don't want an air locker. should i worry until it does blow?
purple 'hoe
Green Bay, Wisconsin
If you have funds, I'd find myself a Detroit Trutrac or a Lockrite.
Or just upgrade to a 14Bolt SF. I don't see the point of putting money into a 10 bolt for the most part
AtomicHoe094
Atomichoe094
cleveland, OH
I didnt put additive in my previous g80 when i changed the fluid and it chattered like a mother...
never chattered before hand. i vote yes do it
arctic388
arctic388
when i placed my order i ordered some slip lock but i wont put it in unless i definitely hear chatter.
probably wont consider other options until the G80 blows. thanks for the links and info though.
AtomicHoe094
Atomichoe094
cleveland, OH
check out the bolt that holds the pin in place. Mine was wearing like in the picture and this is what causes them to go sometimes. Brothers blew up that way, the bolt snapped inside and tore shitup.
There like 6 dollar bolts from murrays or summit.
arctic388
arctic388
thanks for that. i didn't even think to ask what i should look for when i change the fluid. is there any other things i could look for and check for wear while i have it open?
AtomicHoe094
Atomichoe094
cleveland, OH
Look at all the teeth to make sure there wearing evenly, any metal shavings on the magnet, just check it out to make sure it all looks somewhat normal lol..
If your not sure take a few pictures and come back here so we can analyze it for you
BTW.. goodluck! :cheers:
arctic388
arctic388
I googled it and found a majority says it is not required and do not use it and about 3 said to use it. based on what i read GM says not to use it. what i read described it as a mechanical locker not a limited slip device. I have already ordered it, it was a little over 6 dollars, so i just wont add it in unless it chatters bad. - just had a thought - do i need to add any in my front diff? maybe i didn't waste $6
bowtiefreak
No Quarter
Near Philly
According to this:
http://www.youtube.com/watch?v=tTGZOJQQBeE&feature=related
it is both centrifugally activated and uses clutches and friction plates. but correct in the fact the limited slip additive is not needed.
"The maintenance schedule for the rear axle was developed by American Axle &
Manufacturing and GM truck based on multiple tests. The Eaton locker does
not require additional maintenance nor does it add heat to the lube. The
lube will darken due to the carbon wear on the clutch surfaces, much the
same as a disc brake pad & rotor. This does not damage axle components such
as seals or bearings. However, a new axle can produce excessive
temperatures (plus 350 degrees F) due to the ring & pinion breaking in that
will break the lube additives down. Avoid high loads, trailer towing and
high speed extended driving during the initial break in of the vehicle.
After the break in period axle temps will level at a much lower figure.
Lube changes are a good idea because the additives are replenished and
contaminates such as casting sand are eliminated. The axle is filled at the
factory with a synthetic 75w90 GL5 rating made by Texaco under part # 2276.
The GM service # is 12378261. This is the only lube we have done extensive
testing with to insure locker compatibility. The only negative to using one
of these other lubes is an increased potential for clutch chatter. This
really doesn't hurt anything and can be corrected by changing the lube. I
noticed in the latest GM owners manual the term "or equivalent" when
referring to the lube specification. Look for a GL5 rating on the bottle to
make sure the ring & pinion, seals & bearings are protected. Limited slip
additive is not needed."
The following information outlines the type of
rear axle lubrication utilized in GM Truck axles.
I. Fluid Type
II. The 1500, 2500 and 3500 GMT 800 Trucks utilize SAE 75W-90 Synthetic Axle Lubricant. The GM part number is 12378261 and the specification is 9986115."
arctic388
arctic388
my G80 worked well. my open front just spun the non traction side.
msark
I changed mine this summer and added it. Didn't run as smooth as before so within 200 miles I drained the Lucas fluid and additive and replaced with the heavy duty Amsoil.... Had always thought Amsoil was a State Fair Booth hustle but read very positive comments... It was quiet and smooth right off the lift! The stuff is pricy but the difference was real ....
arctic388
arctic388
I am an Amsoil dealer and that is the only brand I will use.
msark
Given you are a dealer you should believe their information and use the product without the additive!
JPeter
