Front and Rear Splash Guards
PauliePucks
NJ
Anyone have these factory installed on their 21? No aftermarket options available unfortunately, but they seem to be a necessary evil.
Stbentoak
Also does anyone see how we can have splashguards on the front if we have the power step going in and out?
These really are a necessary evil and save your body from tons of tar and stone chips....
Bigmanny
I tried to order the fronts from my dealer and was told that they are not compatible with the power step bar.
ytechie
That explains why they show up when you put your year/make/model into the accessory search, but they don't show up when I enter my VIN.
Stbentoak
Well yes, we kinda knew that... the question is ..is there a way to get around that to HAVE front splash guards with power steps? in most instances they are actually more important than the rear for keeping tar and rock chips off the doors and lower body..
scott53
SW PA
I have the front and rear GM mud flaps on my 2021 LT that I picked up last week. I think they look good and will be effective.
SteveW
Did you get instructions for the rear? I picked up both sets but only got instructions for the front. Apparently I have to call the dealer for the rear!
scott53
SW PA
Sorry, can't answer your question as I had dealer install them before I picked it up.
John McElligott
I installed Husky brand mud flaps on the front wheel openings on my 2019 Tahoe with power retractable running boards. They fit just fine. There's just enough clearance for the running boards to work normally.Have the standard chevy flaps on the back.
Jason in DLH
Cheeseburger and Fries
MN
Any word yet if there are mud flaps for the Yukon with power step? Can’t seem to find any myself.
Aaron 21 Tahoe
I do have them. I believe the dealership installed them. They are sturdy. I may have to try and adjust the position a bit. I don't like how they are sitting. 2 sided tape holds the vertical section to the body/bumper. A bit annoyed by that.
PauliePucks
PauliePucks
NJ
Oh man that’s not cool. I thought the clear vinyl was to protect the paint not to adhere the guards. If you would post pics of how they look when you can I’d appreciate it!
brentj
wish there was solution to this!
seems they could have made step bar 3" shorter to allow for flaps.
