For you subwoofer box Guru's
thehoe92
fo sho
The916
hit me up when you are ready to buy those :)
find the cheapest price and I will beat it!
AV8ter
RE's calc is bang on. A lot of debate about it but it is correct.
droppedHoe
Lawrenceville,Ga
??? i used the exact specs with both and re said the box was only like 7.8 cubes but the rockford one showed 11cubes. ??? i had a a software from termpro a few years ago that was on point
WrenchGuy
WrenchGuy
49 x 21x 30 with 16 sq inches of port area per cubic foot.
Should be real dece!
platour22
Jemison AL
L X W X H = / 1728 / number of subs
Example with 2 subs:
49 x 21 x 30 = 30870 / 1728 = 17.86 / 2 = 8.93 cuft per sub.
This is non chambered. chambered box have to be calculated on both sides.
This is also sealed. If you wanted a ported box you have to determine what you wanted it tuned to ( 35hz) then calculate the port displacement.
droppedHoe
Lawrenceville,Ga
after having some pros tell me how to calculate box volume and showing me using a app, i found out the re calculator is a little off, but as much as 7hz off too. thats not good when i want a box tuned to 38hz and it may end up as high as 45hz.
be sure to calculate wood thickness too
so if the box is 49L, internal volume is really 47.5. thats if each side is 3/4 mdf. if its thicker, you have to calculate that
killer20072001
Oklahoma
Whew I was thinkin that was gonna be one tall ass box. Thank you guys for your input its all very helpful. That link that lilsolo68 posted has a calculator for port tunning, and yes I plan on putting in a port was gonna go with 3/4 mdf also.
lilsolo68
tyler,tx
glad i was able to help. post up build pics of the box and the end results
glazar
