Few questions, observations as a new owner
Davidd
2013 Yukon Denali
Assume the Bluetooth only connects to the phone,months allow streaming music from Pandora or my music library?
Bose 10 speaker system is probably good as far as stock stereos but it seems very average to me. Using Sirius radio, I have both the mid and treble turned all the way up and the base, which is heavy,mounted to the middle or one notch below middle. Mid and treble still comes across flatter than it should but ok I guess. Also, the fade needs to be tuned way back toward the rear to create any amt of front rear balance, otherwise, the only thing u hear is the over powering fronts. Is this your experience?
Last, can the auto locks be turned off? I see at shift or at speed but not off. I use my vehicle on a ranch with many gates. The lock unlock will be annoying. My 04 allowed an off setting.
fiatdale
Houstons Best
Houston
Bluetooth in a 2013 is for phone only - no streaming of music. Sirius tends to run flat anyways because of the encoding, so its not surprising that it sounds flat. As far as fade goes, the rear isn't for the driver to hear. Its for any rear seat passengers. The soundstage in these is actually pretty decent from the factory when the fade is set in the middle. I dont believe a full off is allowed on the locks. Usually keep mine at shift since thats when youre getting in / out.
trevsyukon
