MikeW
Just confirming that 00-06 Escalade roof racks, appliques and rear glass/3rd brake light are interchangeable with 00-06 our Tahoes......... Thanks -
Which year Esky gauge clusters swap into 04 Tahoe?
Sent from my LG-LS993 using Tapatalk
i have a nice console lid if anyone is interested grey
It depends on the year the glass came off of and the year of the truck the third light came off of. The 2002-2004 glass is different from the 2005/2006 glass hatch. If your tahoe's glass is 2002-2004, there won't be any holes in the glass and you will need to use adhesive to keep the esky third light on the glass. The 2005/2006 Tahoe and Yukon had a big plastic trim piece at the top of the glass, with screws going through the top to hold it on. Take that piece off and replace with the esky third. Then run the esky third wires down through the hole in the top of the hatch where the middle screw goes and plug into your Tahoe/yukon's third brake light wiring. And flip it backwards. For some reason the orientation of the wires is backwards on the esky third from the wires in the tahoe/Yukon.So all you need to do is remove the Tahoe third brake light and the rear glass will match right up? What about the wiring for the third brake light?
If you're esky third comes from a 2005 or 2006, the mounting screw holes will match up perfect. When I did mine on my Denali, the esky third came from a 2004 and the mounting holes were in different spots. That's why I ended swapping glass hatches. I'm not ok with just adhesive holding the third light and base on. I wanted the mounting screws in place and adhesive. It's been on over a year now with no problems. But if your light and base is the same year than you shouldn't have any problems.I have an 05 tahoe that currently has the 06 glass with the plastic piece on the top of the outside of the glass. Are you saying that the third light will work without replacing the entire glass? I dont really care for the large plastic piece. I had to buy a replacement glass last year as the drivers side hinge delaminated from the glass. The guy at the glass shop said that they replace the 05 glass with the 06 glass to eliminate this issue.
No your stock hatch supports will be fine. The esky base and light don't weigh much. The swap is really easy. Pull the c clips off the hinges and the whole glass comes right off and you can make the swap. Just have an extra set of arms available when you do the swap.Really, I didn't know they were that expensive. I have been loosely looking for one since I replaced the original Tahoe glass last year after the hinge delaminated from the glass. The aftermarket replacement, from an 06 rattles. This one has my Burmuda Blue paint so no trip to the paint shop. Hopefully the rattle will go away.
Will my stock lifts (shocks) be ok or does the third light add a bunch of weight?
