duramax yukon-
jd1
So i was thinking, how hard would it be to drop a duramax into my yukon.....
I wouldnt mind dropping the coin to have it done, but to what exstent of a project would this be?
TheFuzz
Idiot Police
Spurbury, VT
It's not impossible, but it would be a hugely intensive project that wouldn't come close to justifing the cost. It's just one of those things that allows you to have something that very few other people have. For starters, the frame would need to be totally reworked and strengthened to accomodate the engine and allison tranny.
6Gears
Robinson IL
The frame actually does not need any work....it is mostly all in the trans hump and core support. The core is about 2" taller for the intercooler and radiator and the hump is not near big enough for an Ally to fit under. The guy in Apopka has a website and is on "the Dieselplace.com" under TDIguy. He has done a bunch and you can't tell them from factory. The only thing I don't care for is the way he does the body. He uses body lift blocks in the front and uses smaller ones towards the back, kinda like 3", 2", and 1" to make the room up front.
Rollin Thunder
Banned for Repeatedly Insulting Members
Va Beach Va
cummins is missing two cylinders. I dont care how big the pistons are. Give me 2 more.
Repo503
A little off topic but I drove a GL320 when I was at the benz dealership the other day and it was great. I think detroit would see much greater adoption of diesels if they would start making them as smooth and as quiet as the europeans. Not everyone wants to emulate a trucker. In this size vehicle the benefits of diesel are tremendous. I'll probably always be a gas, ass and grass man myself but the benz was very appealing.
Max
Mile High
Denver
I'd have to buy a 2500 burban for that swap, comes with the proper running gear and it'd be alot easier. I'm contemplating a goofy idea for my denali, looking at wrecked c5 donor corvettes for an independent rear setup :D
Crazy Al
Mukilteo, WA
More justified if you're engine is already blown and you want to keep the truck. That was one of the options we kicked around with the shop when replacing the engine in my tahoe, but cost added up fast and a remanufactured 5.3 was the more economical route. Then again we were looking at new a diesel and tranny, probably wouldn't be too bad if you had a donor car.
Drewphil
