Double din
Crippin87
I put one in mine and it wasn't too terrible. I had to have a lot of interfaces for everything to work. One for the bose, one for the steering wheel controls, then I had to buy a new xm vehicle kit for the xm to work with my new indash but i was able to use the factory antenna. As far as mounting it goes, it wasn't too terrible. I just had to Dremel a little piece in the back for it to fit.
JMEngland88
FYI for future members, if you use the PAC interface it has both the Bose interface and steering wheel controls in one. Not sure about the XM though
jaywoo65
Cabot, AR
Must not have been the PAC interface I just installed. I put in the PAC OS-2X. It's steering wheel control ready, meaning they have a wiring harness partially done for it. You still need to buy a steering wheel interface. I used the PAC SWI-RC for it. Do you have a part number that has them both combined?
JMEngland88
Yea, it's the PAC RP5-GM11 that you need. It's an all in one interface, works with both the amplified and non-amplified systems. Super easy to install too, you just wire everything up to the aftermarket stereo's wiring harness in the comfort of your living room, then take it all out and plug-n-play.
fig865
Good, because it's the setup I just bought. And I'm picking up the Pioneer AVH-X490BS from FedEx after work today. That along with an Esky back up camera, I'm hoping for a somewhat simple install. While I'm in there, I'm replacing cluster lights with LED's.
jaywoo65
Cabot, AR
If you scroll down a few posts to Just another Pioneer double din install, that's the setup I just put in. Well, a two part PAC setup but that was still pretty easy.
JMEngland88
Yea it couldn't be simpler. I wired the harnesses together in my living room, then walked outside and threw it together. Once you get the stereo harness wired to the PAC harness, it's all plug and play from there.
Rme76
