Denali clunking in steering wheel CONTINUED, Changeover to non power steering column
hosseface
So, I've had a 15 Denali with power column - it clunked and popped inside the column with any low speed and/or parking lot manuever.
My 16 XL started it too with just a handful of miles. A couple of months back, I posted on there and did the TSB for replacing the column bearing. That only lasted a few weeks and now it is back. The issue only appears to happen with the power tilt/power telescoping steering wheel.
Does anyone have access to a good parts catalog to confirm some parts numbers for me?
I'm tired of messing with this and I am going to switch mine over to a non power tilt and non power telescoping steering wheel. According to the research I've done, it looks like a 16 column WITHOUT power is part # 84047767.
As far as I can tell, the only additional parts needed will be the shroud (since the tilt arm is different than the tilt power button) part # 22834650 and the tilt arm itself 23255512.
Anyone care to comment? Anyone see any reason why it can't be done?
Thanks
DenaliBQ
i had a 14 sierra which has the non power tilt and it clunked even after they replaced that plastic bearing
DenaliBQ
my 16 yukon denali i dont get it tho but only have 9000 miles on it my cousins 2015 yukon denali has it though
HiHoeSilver
Away!
Chicago
Not sure if it applies to K2XX models, but it was common on the NBS trucks, and the answer was usually in the ISS.
hosseface
hosseface
Well I just ordered all the parts so I'll let you guys know how it goes. The power tilt/telescoping column is just junk.
I have zero use for the telescoping wheel and/or power tilt so I'm going to try to get a long term solution here.
dbbd1
I understand your frustration (but that does seem a bit drastic).
I assume it's out of warranty.
PG01
Up here to the right
Just telescopic all the way out and see what happens... only issue would a front collision, youll be eating airbag..
Vector
South Florida
I hate to say this since I am in the market for a '15+ used Denali or Escalade, but shouldn't a $70-$80k SUV not have these type of problems?
I mean between the complaints of wind noise/buffeting, and now this, it is enough to give me pause.
It also reminds me of the cracked dash issue of the last generation where GM punted, along with the peeling chrome door panels, wear marks on the A/C controls, etc.
16 years and they still haven't fixed it yet?.... went thru 3 different upper column revisions on my nbs
Offroad Tahoe
