Cranking problem
mrcajunjoker
baton rouge, la
Ok guys, 08 Tahoe 5.3L 130k miles and it's starting to show evap codes and trouble starting. I'll turn the key and it turns over for 3-5 seconds and never cranks. I'll have to try 2-3 times to finally get it to crank. Is this a known problem or does anyone have experience with this?
Thanks in advance....
GM Customer Service
Michigan
Hi mrcajunjoker,
I am sorry to hear that you are experiencing an issue with your vehicle I understand that you are looking for technical advice. I might not be able to provide you with any technical advice but I would be happy to look into this concern for you. Please private message me if I can be of any assistance.
Jennifer T.
GM Customer Care
ccapehartusarmyINF.(ret)
Gilbert AZ
okay you mite be having evap issues and problems with your fuel pump because the evap system doesnt usually cause anykind of driveability issues
but you are at the same mileage as my tahoe was when it started having cranking issues wich turned out to be the fuel pump and also evap issues
Drewphil
