Center Console Leather 2015 Suburban
Utah
Hello everyone,
I am the owner of a 2015 Suburban LTZ. The center console has an issue with the leather. I searched and this doesn't seem to be a widespread issue. Has anyone else had an issue like this and if so, did they replace the entire unit or is there a way to pull the leather back into place? Thanks for your help. This seems to be the most active forum I have found. With Tahoe's, Yukons, Suburbans, there seems to be several "official" forums.
Denali132
Banned
Wow wonder what caused that! How long after you had it until this happened?
Sent from my iPad Pro using Tapatalk
Utah
Utah
I just bought it last weekend, it has 40K on it and I am not sure how it happened. I am glad you think it's odd also, like I said it doesn't seem to be a widespread problem.
Denali132
Banned
I've never seen anyone post anything on this forum that I'm aware of. The dealer should replace that and wonder what caused it to do that. I can't believe the previous owner didn't have it fixed unless they did that but no idea how they would have. Did you ask them when you purchased it? Hopefully they will replace it.
gat0r
DFW
havent seen that yet
i dont think dealer would take time to take cover off, & try to glue it down. but they may.
Rdr854
Northern VA
If you bought it from a used car dealer, you might be able to get them to fix it if there is some sort of warranty that would cover it.
Did you get it from a GM dealer or CarMaxx?
fiatdale
Houstons Best
Houston
Caused from some big dude always throwing his elbow and arm into it as they readjust in the seat, pulling and stretching the leather loose. You bought it used, they probably wont fix it. You could bring it to an upholstery shop or look for a new lid.
Illnasty
New Jersey
Defly seems odd for 40k but it's all about how much abuse that thing takes from heavy handed elbows. In my my old truck I had to replace the driver side arm rest cause it was dented and beat up but it's normal wear and tear in my opinion. I'm planning on buying a new center console and lower seat and store them cause they will tear at some point.
Stanky
My center console looks pretty much identical to yours. Bought my '15 Tahoe LTZ with ~45k miles from a used dealer. Previous owner was most likely heavyset like fiatdale said above
08HoeCD
If dealer won't fix it, you can.
Disassemble lid from storage cubby.
Disassemble the outer hard plastic components from lid.
Remove staples holding leather (or pleather?) in place.
Re-stretch leather/pleather.
Re-staple in place.
Re-install hard plastic.
Re-install lid to cubby.
Easier than you think.
atrain7474
