Brake Light Switch Plug
2Seven
Wylie, TX
My 2011 LT has an issue with the brake lights staying on. I thought it was the brake light switch down on the pedal. Turns out one of the small wires that plugs in to the switch has come loose. I believe it is the purple wire.
What is the best way to fix this? Should I just order a new plug and splice it in?
Thanks!
tractorpuller
I had this same problem. I think I broke it changing the switch though. I needed it right away though so I took plug apart and soldered a short piece of wire to the pin and spliced it to the wire. Kinda Jerry rigged I know but it was best I could do fast. If you can get the pins that would probably be best.
2Seven
2Seven
Wylie, TX
Thanks for the advice!
I ordered a new plug with butt splices from Rock Auto. Should be here this week.
BadDaddy2003
