Blackbear vs Jet performance
SunlitComet
OBS Jedi-Do Good
unknown at this time.
No bias here please. Seriously what can A BB Tune do for me that the following can't:
Dynamic Spectrum Tuning:
JET offers a wide range of Dynamic Spectrum Tuners for your vehicle.
For more information about our selection of Dynamic Spectrum Tuners click here.
DYNAMIC SPECTRUM TUNERS - Designed for the performance enthusiast who wants total control of their vehicle's programming, the JET Dynamic Spectrum Tuner is a powerful tuning package. JET’s DST software provides you with the tools needed for precise performance tuning using your laptop or PC. Use of this software will give you the ability to modify virtually every aspect of the vehicle’s programming.
Stock programming from the vehicle is initially downloaded and saved to your PC using the supplied JET interface cable that connects to the vehicle’s diagnostic port. The stock programming can be reloaded to the computer at any time to return the vehicle’s ECU to its original state.
The comprehensive, easy to use software allows extensive modification to the vehicle’s software. This allows control of fuel and spark tables, speed and rev limiters, transmission functions, torque management tables and many other functions. Modifications are made using detailed table and graph views for easy and accurate parameter editing. Your modifications are saved as a new file and downloaded to the vehicle’s computer.
DST Gas Part # 14005 Programming Options Include:
  • Fuel parameters including power enrichment and volumetric efficiency
  • Ignition tables including spark advance versus load, knock retard and more
  • Transmission shift points, shift pressures, and TCC apply and release
  • Diagnostic tables including fuel and air, ignition and emissions controls
  • Speed calibration tables to correct speedometer and shift points
  • Idle controls, fan temperature settings and torque management tables
  • Raise or lower speed and rev limiters
  • Disable factory diagnostic trouble codes
To see all of the available features please try our full demo version!
DST part number 14005 will program the following vehicles:
1996-2000 GM Trucks & SUV's with Vortec 4.3, 5.0, 5.7 & 7.4L
1999-2006 GM LS1 Trucks & SUV's with 4.3, 4.8, 5.3, 6.0 & 8.1L
2002-2005 GM/Chevy Envoy & Trailblazer 4.2L
2002-2004 Oldsmobile Bravada 4.2L
2007 Sierra/Silverado Classic w/ LS1 4.3, 4.8, 5.3 & 6.0L
1996-1997 Camaro, Firebird, Corvette & Impala SS LT-1
1997-2004 Camaro, Firebird & Corvette LS-1
1998-2002 Camaro, Firebird 3.8L
2004 GTO LS1
2004-2005 Cadillac CTS-V
DST part # 14005 will allow you to program 4 different vehicles from the list above. Licenses to program additional vehicles can be obtained from JET directly for $100.00 per vehicle. To obtain additional licenses call 800-535-1161.
19Yukon97
Texas
Looks to be just like the Blackbear tune. Just you get to do everything instead of blackbear... I have heard some good things about Jet with alot of fox body mustangs and maros. but ofcourse the blackbear tunes from all the guys on here have been praised. If you get this, let us know how everything goes. once i get my truck done the way i like it im wanting to tune. either with blackbear, jet, efilive, or whatever else there is...
Nick
SunlitComet
SunlitComet
OBS Jedi-Do Good
will do. going to mess with the demo software to explore it. it is $350 and is harder for me to get money for but I could recover cost overtime because I could do three other gm vehicles. Not to mention no waiting for shipping of PCM's.
---------- Post added at 11:30 AM ---------- Previous post was at 11:19 AM ----------
Dammit can't get the demo to run. It is almost like it did no fully install.
---------- Post added at 11:43 AM ---------- Previous post was at 11:30 AM ----------
will call jet on Monday maybe just not compatible with Vista. I guess it is time to break out the old and heavy win 98 laptop.
SunlitComet
SunlitComet
OBS Jedi-Do Good
Got the demo started. It needed to run in win98 compatibility mode.
---------- Post added at 08:34 AM ---------- Previous post was at 08:11 AM ----------
Uh, Ok, I may have a lot of learning to do with this software.
---------- Post added at 08:41 AM ---------- Previous post was at 08:34 AM ----------
Will have to see if I could use some kind of yes/no answers mods first and tinker later without having to buy two different jet programmers. I do like that I can change things at any given moment on up to 4 different vehicles and $100 for each additional one.
Anyone else here use the Jet 14005 unit?
AtomicHoe094
Atomichoe094
cleveland, OH
i feel you just dont get the whole "bang" with jet. Jet has failed in the TBI chip compartment and are the biggest waist of money. Jet for obd2 applications-cant vouch for myself but i cant see them being soo great.
blackbear has it for me, did a sick ass job on my ls1 fbody, speaking of which driving it today and got on it going up the entrance ramp of the freeway shifting at 6200rpms is fun as hell. Way faster then before and i cant complain :)
SunlitComet
SunlitComet
OBS Jedi-Do Good
Do you know what BB uses for programming software for comparison? When going thru the jet demo I ran into dozen of tables and 3d mapping graphs to alter a lot of stuff and am looking at my options for one day perhaps doing tuning myself.
AtomicHoe094
Atomichoe094
cleveland, OH
umm couldnt tell ya. Justin did email me this
PE Mode Commanded AFR and enabling Adjustments
Rev limiter raised to 6600,
Full throttle shift points bumped to 6200
Idle raised slightly to smooth engine
Ignition timing optimized (based on dyno experience)
Various Torque management/abuse management limitation removal
Torque converter lockup modified
Desired shift times decreased and corresponding line pressures increased along with reduction of shift torque management
Engine Fan settings Modified
Young28
The Yukon God
ga
I believe they use EFI live for the tuning software.
Oh HP tuners is another software out there. I dont have any knowledge of either. Just have heard some info about both software's from different tuners.
Poppyj
