belt change
YNOT
Is it a knuckle breaker or is it easy?
BlueTahoe2001
Charlotte, NC
Not sure..But I have to do mine soon! I think you might have to remove the Heat/Fan shroud, and Intake tube to get to the idler.
sschrader
On your 01? Takes about 5 minutes.
Can't remember the size, but use a wrench on the tensioner pulley, take tension off the belt and slip it off. Install new one. If the routing diagram is missing off your radiator shroud draw one up so you know how the belt goes back on.
JasonW4141
