Aftermarket Speakers to replace Bose
RynoHarris
Texas
My parents own an 04 Suburban with Bose and are wanting to upgrade their door speakers. Has anyone here changed out their door speakers without bypassing the Bose amp? How does it sound? Should they purchase 4 ohm speakers or 2 ohm to match the Bose amp better? Thanks for any help.
I should add that they will be replacing the stock radio as well with an aftermarket Pioneer.
Sent from my VS987 using Tapatalk
NathanJax
Vacation Nathan
Administrator
Jax, Fl
Tell them to first swap out the radio, and then see how it sounds. Most of the time, that's enough for just regular people and regular stereos.
If you change out the speakers, you will lose the mid/low bass that the Bose system gives you.
RynoHarris
RynoHarris
Texas
They are definitely looking for better quality and a bit louder. I'm trying to talk them into just getting a 5 channel amp, some good speakers and a sub. Just eliminate any issues the Bose amp could cause. I've read quite a bit about them causing some interference after installing aftermarket equipment with it.
OB 04Denali
Long Beach, NY
Definitely changes the head unit first. Even that I went and changed everything, I changed the head unit first cause I had it and it really was a big difference. Def try it first. Amy questions. I went bigger for the c pillar speakers and center console. Share what I did if you have questions
levilarsen
I did 2 ohm just for the resistance being lower I did 350 watt speakers to make sure to handle whatever just closed off the plug on the wire stopped it soldered the new connector on and put them in the back fired are smaller then the front but if you go with pioneer ts-a speakers I was able to go with the 6.5 in the back to match the front set.
Sent from my VS995 using Tapatalk
mwinfield829
