AC problems
71newlands
Hi I have an 04 denali once in a while drivers side ac just starts pumping out hot air while driving passenger side is still ice cold problem continues till i shut down ac unit completely for a few minutes.This is happening more frequently as time goes on any help with this would be greatly appreciated thanks jim
NathanJax
Vacation Nathan
Jax, Fl
search "blend door actuator"
Super Kevin
Chattanooga, TN
I am having a similar problem on mine. From what I have read, the blend door actuator is probably your problem. You can reset the A/C system by shutting the system off. Then cutting the engine off. After you crank it, turn the A/C on and it should be fine. Mine does this at least once per month in the summer but never in the winter.
mfinta
