I hope to make an useful contribution with this thread.
My curiosity was triggered about getting the right octane grade..
The right octane grade
Lets take the 5.3L Vortec Gen III engine, the compression ratio is typically 9.5:1
So for old engines (pre-electronic management, carburetors ) the hand rule was always, how higher the compression the higher octane grade you need. Otherwise (with too low octane) you get pre detonation and you will hear a "knocking" sound. which is really bad for the engine. I found this old chart on the internet:
If i look at the user manual, GM is saying it will run fine on regular grade 87. According to this chart gas with octane 87 is too low for compression ratio 9.5:1 used by the 5.3 vortec engines.
But i found out, that modern engines can handle even low octane gas by means of computer management of ignition/timing and the use of "knocking" sensors. (or whatever it called for)
But still, i think (especially under stress, towing, mountains, etc) the 5.3 Vortec runs better and more economic with octane grade 90/91. What are you thoughts about that?
Ethanol
In Europe and US gasoline is still more mixed with Ethanol, in Europe regular grade (EUR95) is standard mixed with 5% Ethanol. And according to the US department of energy, in the US contains gasoline up to 10% ethanol. I think its not good for the health of the engine. Ethanol attracts water, and in worse cases you get things like vaper lock. Are there still gasoline's without Ethanol?
Ethanol
