99 Yukon/Poor Mileage/Rear Door Panel removal
SenorPescador
Hola, just got a 99 Yukon, nice truck, not so good mileage, my question is any knowledge on increasing mileage, new plugs... wires? put on a water vapor injection? or maybe even my HYDROGEN fuel cell made out of 6" well casing and SS plates. I need to remove door panel to get to lock mechanism, frozen up, also...... thanks from Burgaw, soon back HOME to El Salvador and I will most likely drive this vehicle only 3200 miles to Iztapa, Guatemala then 5 hrs to La Libertad
jaeross57
What kind of fuel mileage are you seeing?
I'm sure you have the 5.7 engine? Any modifications that you know of? Mine is heavily modified so I know I'm going to get crapy mileage but I had a 96 model and I think I got maybe 14 - 16 mpg on a good day.
east302
Mississippi
im getting maybe 12 i will change plugs and new wires and coil pack,
Just driving around town (versus highway) 12-13 sounds about right. If you have larger tires than the stock size shown on the door jamb label, that will throw off the odometer and your calculation.
exp500
My fleet is pretty consistant at 14.5- 17.5 MPG. If yours is 2 MPG less, It needs Cap/rotor/wires/plugs.
SenorPescador
SenorPescador
I will most likely put on my ** cell 6" well casing 17 SS plates, plastic threaded rod, nuts and washers, tubing i will look for a foto
SenorPescador
SenorPescador
still have leak at driver side on rear hatch, goop worked some! and the side door passenger side lock not working I assume drill rivets out to get to mechanism, duh!! Ill get it off clean it, see if it works better Saludos,
BadDaddy2003
