Hello all, I'm new to the forum and hoping someone may have some insight for me. I'm going to be as thorough as I can so I apologize if I'm long winded. I'm not a certified mechanic, but have been around cars my entire life and have done all of my own mechanic work for many years. I have a very well maintained 96 Tahoe LT Z71 with a 5.7 vortec with 70k pampered miles. The truck is garaged, in perfect condition and basically a weekend driver. I'm the 2nd owner since 2001. A few months ago I started experiencing hard starting and a very slight fluttering low rpm hesitation on the highway at around 70 mph at around 2000 rpms. The hard starting got worse until it wouldn't start at all. I did fuel pressure tests and decided to replace the fuel pump. Dropped the tank in the driveway, that's always fun. Installed a new AC Delco full assembly pump and sending unit. Truck fired right up. But after getting it on the road, still had the highway hesitation. After a few outings, the SES light came on. Actually the light had been on and off prior to replacing the pump, but I didn't have a scanner at the time. So now I scanned it and got a P0300 multiple misfire code. The truck idles perfectly and runs fine. So just to be certain I immediately went for the obvious ignition parts first and installed all new AC Delco cap, rotor, plugs, and wires, cleared the code, drove it for a while and still the same hesitation. SES light came on again and it's now P0308 misfire cylinder 8. I have read many forums saying that the spider injectors or pressure regulator could be the culprit. I also am aware of the notorious leaking intakes on this model. About 10 years ago I fell victim to the leaking intake gasket and had it replaced. Since my new symptoms I've checked the intake and there aren't any leaks or coolant in the oil or in the oil filler cap. I sprayed the entire thing with carb cleaner and can't find any vacuum leaks. I also read the distributor rectifier (I believe that was the name) is also a common problem on these models. I checked fuel pressure and have about 58-60 psi key on not running, 52 running, and jumps over 60 when hammering the throttle, and maintains 54-56 while driving. Everywhere I've read 60 - 66 psi is optimum. So I'm leaning toward spider and regulator, but am not certain as I clamped off the fuel return line and key on not running It read 74 psi. After 5 minutes it only dropped to 64 psi. I'm thinking a leaking injector or regulator would drop pressure much more than that. So maybe very slight leak and/or clogged injector creating misfire? I'm aware that a bad coil, control module and any one of the multiple sensors could cause this problem, but I would expect a different code and I'm still leaning towards fuel related parts. I would opt for the spider injector csfi to mpfi upgrade kit as well including new regulator. I haven't done a compression test, but I refuse to believe such a well maintained low miles vehicle could have a bad valve or rings as the idle is really smooth and it has plenty of power. Any help would be greatly appreciated. I just want to make sure I'm on the right track, and really want to get my Tahoe back in shape. Thanks in advance !
