880 fog light install questions.
roadrageror
ROADRAGEROR
alberta,canada
so i just need to ask a quick question. i got the DDM tuning 880 fog light. there was a thread on here but i cant find it and now its almost the weekend so here it is! instead of a plug in for the fogs there are only 2 wires..i read on here SOMEWHERE that the person just ground down the end of the 2 wires(its actually 2 metal posts) ..and here is where it gets fuzzy..do they just put the ends into the FACTORY harness or where do they go? and do you just tape it up after to seal it from water..got my low beams in yeaterday with out a hitch and cant wait for the fogs..i posted the lows on another thread but ill slap one up here too. thanks.oh yeah there 55w 8000k lows and 8000k 35w fogs
hassoun
Germantown, MD
yeh just put them straight into your stock connecters. make sure you test the fogs before you tape it. you might have to reverse the wires. just use electrical tape and u'll be fine. make sure you ziptie the ballast as high as possible.
roadrageror
roadrageror
ROADRAGEROR
alberta,canada
sweet thanks!! i got a bunch of long zip ties and cant wait for tomorrow! i will throw up a few pics when its all done.
roadrageror
roadrageror
ROADRAGEROR
alberta,canada
i dont think the 880 will fit..i cracked the ceramic coated wire on the side of the bulb trying to push the bulb into the housing so it can turn and "click" i think the bulb needs to be a 1/8 inch shorter.not sure what happens when you crack the coating on that wire..anybody ever have this happen?
So i tried the light and it still works fine so far. i decided that the only way this is going to work is with a hot glue gun. i put a bead around the hole and placed the light in. i held it in place til the glue hardened and applied more to the outside.i then went around it with electrical tape and here is a pic.i recomend taking the fog lights off for easy access as its just two bolts. i am now waiting til tomorrow to put it in and do the other side.i am also going to order some spare bulbs as they are only $15 a pair..(i hooked up the lights to my friends headlight ballast for easy access)
destroyer1362
A work in progress
Midlothian, TX
Thats one way to do it.. I may dremel it, if I do I'll post it up, if it works. Your method looks like it will hold up, but whenever I try to rig something up like that I screw up somewhere.
roadrageror
roadrageror
ROADRAGEROR
alberta,canada
ya another option would be a put a little spacer in there.there were 4 screws that you could take out and put a 1/4 inch of something to make enough room. i got 3 of them out and the 4th stripped so i just glued..lol.
ya i figure im going to get all new headlights/signals/fogs and get a new grill next year with a street sceene insert(already have the insert) so it didnt bother me that they were glued and taped.ill do the spacer with the fogs then.(would be alot easier if the bulb was just a bit shorter.lol.
but anyway i had my first night time drive last night and i couldnt stop smiling!!! one of my best mods yet! you see the difference is CRAZY!!
foreverfalcon40
still waiting on mine...
What do you mean spacer? Take pics of the wiring you had trouble wit? Whered you mount your ballasts?
Would love to have this project done in 1 day I'm just an ******* when it comes to wiring...
only systems and guages and I'm good.
roadrageror
roadrageror
ROADRAGEROR
alberta,canada
actually when i saw all the wires together it made sense where to plug the wires in.so that was pretty easy.i mounted the ballasts with very long zip ties about 14" ones, i got them tucked under the bumper cover beside my tow hooks.that place looked pretty dry and clean.i will see if i can grab a pic in a day or two
SFBerto415
California
@ Roadrageror: Did you ever get around to taking a pic of where exactly you placed your ballast under your bumper? Also, do you think you can point out in the pic what the "spacer" looks like.
I looked around under the bumper too when I was attempting to find a nice spot for my ballast, but I could not find where exactly to tie the zipties to.
foreverfalcon40
Well, my truck sits and an Angle so of course it aims down to the ground!
So I ended up removing the plastic bolts and replacing them with bolts, nuts and washers. This was in order for me to AIM the Foglights so I can actually see at night. I also used 4 washers on bumper bolts to push the whole Foglight Housing back so I can move the light with out it hitting the bumper.
My only problem is that the bulbs melted inside the fog light housing!
AdrienR
